Carlson Survey 2012 Standalon ACAD Engine
12 Users
(@kris-morgan)
How in the HELL do I get the drawing to remember what freaking coordinate file is associated with it? I never had this problem in 2008, and tech support, while they were great about the few text issues I found, never replied to me about how to keep the coordinate file handy.
Also, near as I can tell, there won't be any patches so I'll have to suffer through this BS of setting the coordinate file every time, until 2013 comes out.
*miffed*
Posted : 22/08/2012 11:20 am
(@shawn-billings)
Famed Member Registered
is it creating an ini file? that's what connects the dwg to the crd.
Posted : 22/08/2012 11:21 am
Illustrious Member Registered
Since I've only ever used Carlson in it's 2012 version I thought that was just how Carlson was. It is a nuisance. FWIW, I think your wait for 2013 is about over. It's either already available, or about to be within days.
Posted : 22/08/2012 11:28 am
(@kris-morgan)
Sure does, and it still loses it. I have many drawings tied to only one CRD file and I cannot keep it attached when I close and then reopen. It takes 2 seconds, but I never had this problem before.
Posted : 22/08/2012 11:51 am
(@landman)
Estimable Member Registered
2013 has been out awhile now and it has the same issue.
Posted : 22/08/2012 12:33 pm
(@cptdent)
Noble Member Registered
I am on the 2010 version and it is simply a matter of SOP to set ther crd file whenever you open a drawing. I have used Carlson Survey since 2007 and have never seen it open a drawing with the crd file preset or reset to the last used crd file.
Posted : 22/08/2012 12:39 pm
(@andy-j)
wow, any reason why?? that seems nearly dangerous. or at least stupid.
Posted : 22/08/2012 12:41 pm
(@d-j-fenton)
I have been using Carlson on top of AutoCad since '02, and the crd file is ALWAYS attached when I open an existing drawing. I personally have Carlson 2011 with intellicad, and I have never had a problem with it either.
Is this a problem specific to Carlson with standalone ACAD?
Posted : 22/08/2012 1:07 pm
(@djames)
I am not seeing that problem in the autocad 2012 version . My coordinate file shows up everytime . I do have my data directory set to the drawing directory in carlson settings, if that does anything .
I am never asked to find the crd file unless I move drawings around .
Posted : 22/08/2012 1:11 pm
(@carl-b-correll)
I have this problem quite often, Dennis. I don't what causes it. It does seem to happen more when I have multiple drawings open.
Posted : 22/08/2012 1:14 pm
(@carl-b-correll)
> *miffed*
Like someone else said. It's just SOP to make sure you are linked to the right crd file. I do notice more problems when there are multiple drawings open, FWIW.
Carl
Posted : 22/08/2012 1:15 pm
(@glenn-breysacher)
Prominent Member Registered
I've had this problem too. No rhyme or reason that I can tell. Like you, I wish I knew how to keep the two attached to each other permanently.
Posted : 22/08/2012 1:47 pm
(@jim-oneil)
Carlson Survey 2012 Intellicad
Intellicad doesn't have that issue.
Not sure why Autocadd does.
Posted : 22/08/2012 2:26 pm
(@kalston)
Eminent Member Registered
Same thing happened to me on a reinstall. I or it somehow created a subfolder under and with the same name as my original (projects folder). It is a pathway problem, it is searching for the crd. file in the new subfolder which is empty. Lon at Carlson helped me with it.
Posted : 23/08/2012 6:29 pm
Share:
