I use TM9.6. I like it better than TM 9.7 and later versions have less commands(on the drafting/default module, so I never upgraded.
In April or so of 1999 Spectra sent out a patch to fix the label function, which would not place a leading "0", in bearings of less than 10 degrees.
I seem to have lost that patch and wonder if anyone might have it?
RETIRED69, post: 326981, member: 1248 wrote: I use TM9.6. I like it better than TM 9.7 and later versions have less commands(on the drafting/default module, so I never upgraded.
Dear "Retired",
This is part of Geocomp Systems 10.61J revision of Terramodel. You would need a subscription to get hold of the patch but unfortunately you would also end up with all the other refinements, bug fixes and and additions.
Regards,
Jerry
