Revit Conversion to DXF or DWG
(@jms66)
Trusted Member Registered
Is there a simple way or utility converter to convert Revit files to DWG files...?
Posted : 07/04/2022 4:06 am
(@leegreen)
Noble Member Customer
Posted : 07/04/2022 4:14 am
(@jms66)
@leegreen?ÿ
Thank you Lee,?ÿ however I did not explain my issue correctly, I do not have the Revit program to export to dwg, architects are utilizing this program for all there designs and its like pulling teeth to get them to convert files for you and when they do they don't give all the information you need, I can pull the Revit files themselves off of Pro-core but I have nothing to open it with and all the files are the latest 2022, I tried downloading a 30day trial version of Revit but I would need to upgrade my system which isn't old, I was hoping there was a simple other way to do this without paying extortion fees to Autodesk.
Thank you Lee for your time and all others who reply.
Posted : 07/04/2022 4:39 am
(@ladd-nelson)
Prominent Member Registered
@jms66 Depending on your underlying technology application, IntelliCAD and/or the Carlson CADnet module support Revit attach, import and explode.
I hope this information helps.
Posted : 07/04/2022 7:29 am
(@dave-o)
Honorable Member Registered
InnaPinch
I'm using the 2020 version.?ÿ If you have that or less available, I can convert for you.
Posted : 07/04/2022 10:41 am
Share:
