Resection in SurvCE 6.17 problem
10 Users
(@honza)
Eminent Member Registered
I do a lot of resection on construction sites and experienced a veird problém. After measuring all points I go to calc section where I can see two tabs with results and residuals. Very often the residuals tab shows blank. It is 7 times blank and three times with residual values.
I use Carlson Surveyor2 and work in 3Q with negative coords..
I contacted Carlson support and as the SurvCE is not supported any more, there is not help from them.
I wander if this happens to me only or is more common.
Posted : 02/08/2024 4:07 am
(@chris-bouffard)
Noble Member Registered
I have no idea how to address your issues but am wondering why you work in negative coordinates.
Is there a reason for this?
Posted : 02/08/2024 5:35 am
Illustrious Member Registered
Ditto with the negative coordinates; Why? Just to be clear are you saying you work in quadrant #3 where the origin point is to the northeast of your location?
I don't use Carlson, but is it possible that not working in Quadrant #3 could be an issue. It would be for me just thinking about the math.
Posted : 02/08/2024 5:49 am
(@honza)
In my country we have such a projection. It goes back to 19. century and before a computer age they were positive.
Posted : 02/08/2024 5:58 am
People are asking about this negative coordinates business because it is very unusual, and we are all wondering if it has something to do with the effects you are observing re: residual reporting. The use of a computer to calculate the coordinates shouldn't have anything to do with it.
I'm wondering how many control points you are using for your resections. I'm not specifically familiar with SurvCE, but when I used Survey Pro it would not report residuals if resecting to just two points. You needed three or more to get a residual report.
Posted : 03/08/2024 12:13 am
(@honza)
We have +X going South and +Y going West. The computer age brought CAD programs and our projection is now in Q3 and negative for CAD calculation.
I usually do a resection with a minimum of four points. Sometimes the residual tab remains blank but overall values for horizontal and vertical shows up every time. Also in RW5 are stored all values but for the check and removing bad residuals it remains blank like empty Excel. I can tap to a cell and it shows point ID and coords. All the information are there but sometimes just don't show up and it is very frustrating especially when for example use wrong prism height etc.
Posted : 03/08/2024 3:51 am
(@chris-bouffard)
I don't understand the point when you are working in +X and +Y in the field and negatives in CAD. Both the field work and CAD files rely on 0,0 orientation. Trying to bring positive coordinates into a drawing based on negative values could have your points potentially falling miles outside of the drawing.
Posted : 03/08/2024 5:50 am
(@cf-67)
Honorable Member Registered
I have recently received support from Carlson regarding SurvCE 6.
Although Windows Mobile is defunct, Carlson are still supporting SurvCE users - according to their website, and according to my recent experience.
Were you talking to a rep in your country, or to the head office in the US?
I would try again to contact them.
Posted : 03/08/2024 7:45 am
(@honza)
I contacted their support in the US for several times, I sent them CRD and RW5 for this case but SurvCE has zero priority now.
Posted : 03/08/2024 7:58 am
(@mathteacher)
I don't know much about surveying software workings but I do know a thing or two about coordinate systems. Using South as Positive x and West as Positive y raises a red flag.
Typically, the y-axis is the North-South axis and the x-axis is the East-West axis. In the old, old days in the US, due South was 0 degrees, due West was 90 degrees and so on. Rotating the system 180 degrees gets us to our current system of due North at 0 degrees and due East at 90 degrees.
In the plane system that you've described, a similar rotation of axes is possible, so that's ok.
The other potential problem is the definitions of x and y. Typically, the y-axis is North-South and the x-axis is East-West with North and East positive.
Possibly, you're in the third quadrant because of a misunderstanding of the coordinate system in the computer system.
As to the zero residuals, I haven't a clue, but I would check the coordinate system definition and see if that eliminates the negative coordinates.
Posted : 03/08/2024 10:19 am
Famed Member Customer
If the negative coordinates or South azimuth were the issue, the blank cells would simply have incorrect values. Blank tells me software or procedure problem. Walk through your procedure, recording each step (and resulting screen appearance) as you do it. Find your blank lines and check for any differences in your notes.
Best of luck..
Posted : 04/08/2024 1:27 am
(@honza)
The issue is blank cells from time to time. Calc with negative coords is without any problem. This is what I stated above. The customer service in the US asked me for CRD and RW5 to track the possible sw problem. They got all they asked for but as I stated there is no priority to sort it out (I asked for several times).
Posted : 04/08/2024 2:44 am
(@cf-67)
Do you also have Carlson Survey CAD program on your laptop/desktop?
If so, you can run the raw data through the included SurvNet program and it will solve the resection and report residuals.
At least then you will know if it is purely a SurvCE issue or if it also occurs in another program.
You could also download a demo of SurvPC and try that.
Not solving your problem, but those are my thoughts.
Posted : 04/08/2024 10:05 am
(@chris-bouffard)
The demo version gives you a limited number of command calls and if you are not a Carlson user, you will blow through them quickly. I think that the max is 100 command calls in the trial version.
Posted : 04/08/2024 10:25 am
(@ladd-nelson)
Prominent Member Registered
Unless I'm mistaken, wouldn't these vectors result in a "left-handed" coordinate system as opposed to the more tradition right-handed system?
I can't say with certainty if this is at the root of the problem but it very well could be. If you'd care to send your data files and coordinate system information to me lnelsonATcarlsonswDOTcom (or reply to me with the Carlson Tech Support Case number), I'll see if I figure out what is going on.
In case it helps, you do have the ability to set a traditional Cardinal direction to a 0° azimuth:
I hope this information helps.
Posted : 06/08/2024 6:22 am
Share:
