Insert a SD card under base cap. ?ÿAssuming you have Terrasync do as above suggested write data to shapefile on card. ?ÿAssign shape a GCS WGS84 prj. ?ÿThis is fast but your using autonomous solutions, muse well use a Garmin ?ÿ You have to pp to reap 30cm or so
youll want to PP either available in PFO or positions and get CaD, ascii out. ?ÿPFO will install on win11 and you??ll get the data transfer utility. ?ÿYou won??t be able to install WMDC so install USB switcher app. ?ÿI??m me with a better switcher install doc than Trimble. ?ÿ
Posted : 08/02/2023 10:13 am
