I am going to be staking out some curb in the near future and was curious if there is a way to calculate a radius point from existing linework and/or existing points along a curve? Typically the radius points are given to us in the CAD files but occasionally they will be missing and I??d like a way to quickly calculate one while in the field. I??m aware of how to create points on a curve from the map screen so I assumed there??s a way to calculate the RP from the PC and PT.?ÿ
Yes. Use the snaps create points from cad line. Pretty simple really. Try it.
Contact me if you need more.
@leegreen after I select the cad line I see the option to create>points> and then select “Curve RP’s” but that doesn’t seem to be working.
The line doesn't contain an arc.
there has to be a way to do a distance distant intersection for be able to calc in by swinging the delta.
