Magnet Field - mmGPS Setup vs. Pocket3d - mmGPS Setup
2 Users
(@ctrunkle)
Trusted Member Registered
I am having some continuity issues when trying to setup our mmGPS system with my Magnet Field software. To give you some background information, we have set up a single LZ-T5 laser on a known control point, calibrated it, and tested it using Pocket3d, checking in perfectly on several control points. However, when I attempt to set this up in Magnet Field I consistently shoot .08 low on control points. I assured all my control information was constant, the slant/mark measurement on the laser is the same, and the control point it is set up on is correctly entered in magnet. I can tell i'm overlooking a simple setting somewhere that would affect the height of either the laser or the instrument, but I can't seem to pinpoint where that setting is.?ÿ
I have ensured the height of the laser, height of the antenna with mmGPS receiver, and the control point the laser is currently on are all correct and match what I used in Pocket3d. To further this, when I point the receiver away from the laser while setup on a control point, my elevation is perfect, which, as previously mentioned, is what is leading me to believe there is a simple setting that affects the height.?ÿ
Thanks for the help
Posted : 24/04/2023 10:08 am
(@leegreen)
Noble Member Customer
Are you using the same mmGPS control file (*.gc) exported from Pocket3d, then imported into Magnet?
What version of Magnet Field?
What model GNSS receiver/antenna?
Have you checked the latest firmware? Have you contacted your dealer?
Are you using the same rod and mmGPS with both software?
Posted : 24/04/2023 11:59 am
(@ctrunkle)
@leegreen yes. It is the exact same .gc3 file exported from Pocket3d AFTER I had set it up in Pocket3d and calibrated the laser. However, I notice when I imported that .gc3 file into magnet, it did not include the transmitter data like it does when you import into Pocket3d. I had to connect to the laser via Magnet and “Get Data”.
I am using the most recent version of Magnet Field, I believe 7.3? With a GR-5 Base/Rover. The same rod is used for both applications, same height, same everything. I have contacted my local dealer/support rep but I typically come to this forum in the interim as you are usually very helpful.
Given that I am getting the correct elevation when using only GPS, I know it’s a setting within the mmGPS setup, I just don’t know where or what exactly. There aren’t too many people I’ve come across who know a lot about using mmGPS with magnet
Posted : 24/04/2023 5:26 pm
(@leegreen)
Are you using the quick connect adapter on the bottom of the GR5?
Have you tried the mm setup with Magnet,  then send it to Pocket3D?
Posted : 25/04/2023 3:09 am
(@ctrunkle)
No quick connect on the GR5. Just a 2m pole, mm receiver, and the GR5 screwed directly onto that. Zero difference in setup. I have not tried the sending the mm setup to Pocket3D from Magnet.
Posted : 25/04/2023 3:16 am
Share:
