LGO & Leica GS18T
(@geo-cutter)
Active Member Registered
I am going to update my GPS gear in the near future. For economic reasons I don't quite want to jump to Leica Infinity just yet.
Does anyone know if I can use LGO to download, upload, create transformations, etc. with a GS18T?
Posted : 01/12/2022 6:36 am
Illustrious Member Registered
I'm sure you could convert to to RINEX and work with that. Would you be working with Captivate? I'm using a GS18I. I've zipped and attached a file of RTK ties, give it a try and report.
Posted : 01/12/2022 11:40 am
(@hpalmer)
Honorable Member Registered
Not sure LGO supports Beidou and Galileo.?ÿ But what a great piece of software for static observations.
Posted : 01/12/2022 3:53 pm
(@shelby-h-griggs-pls)
Noble Member Registered
We moved to a GS18i almost two years ago and got a seat of Infinity, so I haven't really tried LGO with GS18i data. There are lots of things that probably will NOT work, no photo support from the GS18i camera, I don't know about tilt measurements, but likely also not supported. For static baseline processing maybe OK, but additional constellations over GPS/GLONASS may not be supported? Of course if you only have GPS/GLONSS on the GS18i currently that isn't an issue. The GS18i does store raw files that at least are named similar to older Leica receivers, ie: mbd files
Honestly, I would probably just spring for Infinity even if LGO could limp along with somewhat limited functionality.
SHG
Posted : 15/12/2022 1:26 pm
Share:
