Grip Edit Problem
5 Users
(@moe-shetty)
Noble Member Registered
Good morning, grip edit does not work at all in my CAD from Carlson, running with Intellicad 9. Any ideas to enable grip edits?
Posted : 11/07/2023 6:37 am
(@learner)
Estimable Member Registered
My grips are working with GRIPS variable set to "2".  Sometimes things get changed somehow...
Command: GRIPS, enter "2"
Let me know if that helps.  You've probably already rebooted....
Posted : 11/07/2023 7:47 am
Illustrious Member Registered
Hey Moe,
GIF
What problems are you having?
@ladd-nelson
Posted : 11/07/2023 7:52 am
(@moe-shetty)
@learner grips only have 0 (off) or 1 (on), regrettably, i have tried them and still no change
Posted : 11/07/2023 8:34 am
(@moe-shetty)
it's like that today, yes
Posted : 11/07/2023 8:35 am
(@ladd-nelson)
Prominent Member Registered
@moe-shetty
Newer versions of AutoCAD and IntelliCAD do permit the GRIPS variable to be 0, 1 or 2:
https://help.autodesk.com/view/ACD/2024/ENU/?guid=GUID-97AD30F3-A1A3-4027-91B7-49008841A447
When you list the entity(ies) that are experiencing the problem, what do they list as (e.g. XREF or BLOCK/INSERT, etc)?
Also, are the entities on a locked layer?
If an AUDIT is run on the DWG, does that action correct the problem?
Does the behavior happen just in one DWG or all DWGs?
Which build (Help -- About Carlson) are you running?
Hopefully this points you in the correct direction.
Posted : 11/07/2023 6:12 pm
(@mag-eye)
Reputable Member Registered
Check your selection options.
Posted : 12/07/2023 10:26 am
Share:
