FEMA Firmette Format
(@dave-reynolds)
Reputable Member Registered
I used to be able to get FEMA Firmettes that had a copy of the FIRM panel title block on the right side of the map. I can't seem to find that now... any hints?
Posted : 23/10/2020 7:07 am
(@squirl)
Noble Member Registered
(@dooryardsurveyor)
Trusted Member Registered
@Dave Reynolds I believe that format you are looking for is only available on the older Firmettes where you manually adjusted the area you wanted to see before you printed. The new dynamic map Firmettes do not have that full title block you are looking for, but after searching for the address you need you can click the "Show ALL Products", then click "Effective Products" -> "FIRM Panels" and then click the "View" on the far right for the panel you want and that will let you make a Firmette with the full title block using the Intranex Viewer.?ÿ
That at least works for me in my area, hope that will work for you as well!
Posted : 23/10/2020 8:07 am
(@dave-reynolds)
@dooryardsurveyor Exactly what I was looking for, thank you!!
Posted : 23/10/2020 7:25 pm
Share:
