Deed Reader Pro - Plot Deeds in Seconds
18 Users
(@tyler-brown)
Trusted Member Registered
@matt8200
I have a few comments/questions after briefly using Deed Reader Pro v2.0.
  1. This app works great for those metes and bounds descriptions that describe one parcel.
  2. Many of our deeds describe multiple parcels in the same deed. The app seems to pick one of the parcels at random and ignore the rest. It would be good if it could read each of the parcels and provide separate calcs with closures.
  3. I’ve noticed the app will sometimes ignore calls even though they are already in the description. It would be good if there were a way to simply highlight the call and assign it to a location in the call table,
I can post a few examples if you need.
Posted : 20/06/2023 9:15 am
(@matt8200)
Estimable Member Customer
Hi Tyler,
The app should be able to detect all the parcels in the pdf or image file.  Did you try pressing the plus button to cycle through the descriptions in the file?
Also in the latest version of the manual I describe a method to use Snipping Tool to snip out a parcel from a long pdf.  The updated manual did not get included in the latest version like I intended but it can be downloaded from https://www.deedreaderpro.com/how-to-use .  Also watch the Getting Started video if you haven't yet.  I am still in the process of updating so that it matched the new examples and features in the latest version.
Regarding some calls not being recognized.  This is likely because they are not proceeded by 'thence' and this topic is covered in the manual:
If you are still unable to get some deeds to process properly please email them to me and I can help you with them: support@deedreaderpro.com
Posted : 20/06/2023 11:06 am
Illustrious Member Registered
I plan to just do screenshots of each legal like I already do when I do OCR, whether there are one or multiple descriptions per document.
Posted : 20/06/2023 11:35 am
(@matt8200)
I just released Version 2.1 which fixes a couple of issues and bugs that were found in yesterday's 2.0 version.
Version 2.1 (June 20, 2023)
- Fixed bug with "View Highlighted Image" not working when "Isolate Metes and Bounds Descriptions in Deed Text" is not checked.
- Improved error handling and bug fixes for "View Highlighted Image"
- Fixed text scaling when High DPI Display Scaling is set to 125%
- Updated the manual
Posted : 20/06/2023 12:34 pm
(@tyler-brown)
Taking a screenshot of each description works. It did not recognize one of the metes and bounds parcels until I separated it in its own file.
Does this application have a way to process a call that "bears" a certain bearing and distance from the starting point?
For example, "Beginning at a point which bears N84deg 21'32" East 137.32 feet from the westerly corner of Lot 100."
Posted : 20/06/2023 1:15 pm
(@matt8200)
@tyler-brown
It does not have the ability to process that yet.  I plan to add that feature in the future.
Posted : 20/06/2023 1:20 pm
(@jac1303)
New Member Registered
Is this still being worked on? Very interested in it. We do a lot of deed plotting and working a lot ocr recognition of old deeds.
Posted : 23/02/2024 4:43 am
(@matt8200)
Yes, I have been very busy working on Version 3 of Deed Reader Pro which will have many new features and improvements. I hope to release it soon and will make an announcement when it is released.
Posted : 23/02/2024 7:44 am
(@jac1303)
I guess older versions aren’t available?
Posted : 23/02/2024 9:17 pm
 adam
(@adam)
Noble Member Registered
Awesome,
I have been using Deed Reader Pro for the last six months and it has saved me many hours. Looking forward to version 3. Nice work Matt!
Posted : 26/02/2024 11:30 pm
(@matt8200)
In response to a question about cursive deeds:
Optical character recognition of old cursive deeds is very difficult. Google Cloud Vision is the only OCR engine that I have found that read the old cursive deeds. It does not work well. The text still contains many errors and I don't think it is good enough yet for me to implement into Deed Reader Pro. Here is an example of the text generated with Cloud Vision for the description in the attached cursive deed:
Beginning at the south east corner of taid quar and being led, thence west one hundred and sixty two poles and seventeen linter to the south west comer of taid east one hundred and thirty poler poles and thirly links to at pact, the cutes tection, thence nath sixty sit and seventeen links to a post and tone, thence nath fourteen poles and leventy links to a Make and stone, thence east thirty two poles to a stake and stone in the east line of said section, thence fouth. righ by one poles to the beginning, Containing sevenly accez, bes the same. more or left.
In Version 3 of Deed Reader Pro which I hope to release in the coming week data can be directly entered into the Call Table. This will allow you to manually enter and plot deeds that cannot be read by the OCR.
Posted : 05/03/2024 5:39 am
Page 4 / 4
Share:
