Civil 3D + Map3D [Complete Autodesk Solution]
2 Users
(@therock003)
Reputable Member Registered
Let me get this straight. Is Map3D a subset of Civil 3D? So if a business purchased civil 3d product license, it includes full map3d functionality inside? If i understand this right it does..
https://forums.autodesk.com/t5/civil-3d-forum/civil-3d-vs-map-3d/td-p/6827792
https://forums.autodesk.com/t5/civil-3d-forum/is-the-autocad-map-included-in-the-autocad-civil-3d/td-p/3365645
-Also id like to know, in case someone purchases civil, can they launch Plain Autocad, if no heavy work is needed, just for system performance sake?
-And then on top of that you can i suppose install every other module like raster design -3rd party (Carlson/Dotsoft etc) and have it insde the C3D Workspace?
Posted : 12/01/2019 7:46 am
(@twdotson)
Estimable Member Registered
Map3D is built on plain AutoCAD and is recently available as part of the AutoCAD One plan.?ÿ Civil3D is built upon and contains Map3D.?ÿ It's just a matter of pulling down a workspace drop down to choose "Planning & Analysis". When Civil3D installs it creates a "Civil3D as AutoCAD ####" shortcut which launches as plain AutoCAD, usually starting a little quicker.
Then you have all of plain AutoCAD, all of Map3D, and Civil3D.?ÿ Since AutoCAD is the foundation you can easily add 3rd party add-ons (thanks for considering us), etc.
Posted : 12/01/2019 8:01 am
(@therock003)
Thanx a lot, this settles it
Posted : 12/01/2019 9:16 am
Share:
