Carlson Software w/autocad-Grading model vertical faces
2 Users
(@terminus-nc)
Estimable Member Registered
Good morning.....Do you guys who make models have an alternate suggestion on creating vertical faces on a model than what I am currently doing? Since I started modeling, I found that creating 2 3DP's staked over each other at different elevations caused issues and the software doesn't seem to recognize one of the 3DP's (Or worse it switches recognizing the vertices in different places). My work around for this has been to offset one of the 3dp's 0.01' (these models are for grading so they don't really care the cut face isn't perfectly vertical was my thinking).......So is there a different way to get the triangulation to recognize the 2 3dp's without offsetting them?
Posted : 27/08/2023 3:34 am
(@va-ls-2867)
Honorable Member Registered
You have to have slight horizontal separation to model correctly.  You cannot have 2 lines identical horizontally with differing elevations.  Triangulation is always looking for the 3 closest points.
Posted : 27/08/2023 5:38 pm
(@terminus-nc)
Thank you
Posted : 28/08/2023 12:31 am
Share:
