Any civil3d experts here?
10 Users
(@jimcox)
I have Civil3d on my desktop.
I have a dwg file from our land information database - 2d polyline of some local land parcels
It opens in Civil3D and the coordinate numbers look reasonable.?ÿ
It goes as a background for Access
I want to play with the linework etc
But if I save it from Civil3D.
In Access it changes scale and shifts.
It looks like the coordinate system is borken. Perhaps something to do with units &| false origin.
Any thoughts or suggestions very gratefully received.
advTHANKXance
=Jim=
(I would use raw AutoCad if I could. Unfortunately that is not an option here)
Posted : 30/03/2023 10:39 am
(@said-lot)
Estimable Member Registered
The the Civil 3d drop down at top left-->Drawing utilities-->Drawing settings for starters. This will show if a coordinate system has been assigned and what units are assigned.
Posted : 30/03/2023 11:15 am
(@frozennorth)
Honorable Member Registered
This.  The units may be specified in your coordinate system, then also as Drawing Units in this same dialog.
Also type command "units" to check drawing insertion units.
Honestly, I reached an impasse with Civil3D on this kind of thing the other day when connecting to a geodatabase and had to resort to ArcMap.
Civil3D does not always handle coordinate systems well.
Posted : 30/03/2023 11:23 am
(@geoff-ashworth)
quote]
No kidding! You also have to be aware whether the units are Feet or US Survey Feet. That has bitten us before.
Posted : 30/03/2023 4:16 pm
(@jimcox)
Bingo - that was it.
The units were wrong and no coordinate system defined.
Saved data now appears where expected
Thanks for your help
Posted : 30/03/2023 5:17 pm
(@ncsudirtman)
Reputable Member Registered
Yes this can def bite you in the butt. Also, set the projection info & units prior to saving any new drawings. Set it both in the projection tab & units tab under the big “A” icon - imported a set of points the other day & forgot to do so somehow so everything was exactly the same distance apart from an X-REF’d previous survey that was setup correctly
Posted : 30/03/2023 6:22 pm
(@jimcox)
@ncsudirtman
Thanks for the tip.
My copy of civil3d is very 'raw' - no real setup, templates etc.
What gets me is that the original file 'works'
But the save screws it up
Guess it is not just Access that has it's quirks
Posted : 30/03/2023 9:25 pm
 jph
(@jph)
Famed Member Registered
I'm might be going out on a limb, but going to assume that Jim isn't working in US feet in NZ
Posted : 31/03/2023 4:15 am
(@blitzkriegbob)
That's pretty unpatriotic of them!
Posted : 31/03/2023 6:53 am
(@wa-id-surveyor)
Prominent Member Registered
@ncsudirtman
Thanks for the tip.
Setup Civil3d .DWT templates with all the appropriate coordinate system and unit settings.  Then, when you start a new drawing, choose the appropriate template and you're good to go.
Posted : 31/03/2023 9:16 am
Illustrious Member Registered
Your C3d experience will dramatically improve once you have prepared a template to work from. But don't expect to get it all set up in one go. Do it in stages and improve on it.  I've been working on mine for 7 years.
Posted : 31/03/2023 11:47 am
(@rover83)
Noble Member Registered
My workflow has always been to export DXFs from Civil 3D using WBLOCK, so I can strip out any unimportant items (and layers) to reduce file bloat and crew confusion, and also so I can choose "Unitless" as the export unit to avoid any possible scaling/shift errors.
~15 years of C3D usage has taught me that DWG format is much more likely to burn you than DXF when importing to other software packages...
Posted : 01/04/2023 6:06 am
(@jimcox)
@norman-oklahoma
Actually I dont expect to set up any templates at all.
I'm using it for data manipulation and examination - not production.
All I really need is 'plain Jane' AutoCAD
Posted : 01/04/2023 9:21 am
(@jimcox)
Yes, oh yes. So very true.
Posted : 01/04/2023 9:22 am
Share:
