Access - Georeferencing A Map
1 Users
(@bstrand)
Noble Member Registered
So the other day I started tinkering with something that ended up being really slick.  I exported an .xml file of some boundary linework into my data collector with the intention of using the georeferencing function to move it onto found monuments.
It worked similarly to localizing where you pick a linework point and a matching ground point.  The issue I ran into, that I'm curious if there is a fix or adjustment for, is the .xml linework was moved onto the first point I selected and the second point was apparently only used for rotation.  This caused there to be a 0.40' difference between the second ground point and its corresponding .xml point.  This was close enough for searching purposes but I'm wondering if someone might know of a way to cause the .xml linework to be centered between these ground point pairs instead?
Posted : 03/03/2023 11:20 am
Share:
