Topcon Hiper Rover ...
Topcon Hiper Rover connection time
(@dave-m)
Hi,
I have a Topcon Hiper Pro system, about 3 years old. When I set up the base, the FC100 connects relatively quickly via Bluetooth to the base, but I often have to wait 10 minutes or so, for the rover to connect to the FC100.
Once it's there it's fine for the day, so I have no problems with that. This seems to be getting worse, although I can't be sure about it. A few times, maybe 10%, the card is not recognised, so has to be taken out and put back in.
Is there a way to help it on its way?
Dave
Posted : August 13, 2010 5:32 am
Bluetooth is some sort of 2 way radio handshake, whereby they find each other, and work together.
Sounds like (to me) you should try a different data collector, and see if it is at the DC end, or the Topcon end.
then, you will have 1/2 of the equasion solved, maybe.
Posted : August 13, 2010 7:44 am
(@blakehuff)
I have had that problem when I shut down the data collector before closing the job.
Posted : August 13, 2010 8:20 am
(@dave-m)
Might be on to something there, I usually just shut the whole collector down. A proper organised sequence of closing files and shutting down is obviously what should be done. I will have to experiment.
Dave
Posted : August 13, 2010 8:25 am
