Truncated Posts
Truncated Posts
(@stephen-ward)
Several times per week I see a post or reply that appears to be missing part of the message. For example, when I look at this [msg=257321]one[/msg] it ends with "So I sent him a proposal and 3 days later received the signed proposal and". It's as if he clicked the submit button mid-thought. Typically when I come back an hour or so later I'll see that the remainder of the post has appeared.
Am I the only one?
Posted : April 28, 2014 9:44 am
(@christ-lambrecht)
did not happen yet here at my side,
Chr.
(IE9, Chrome & FireFox user.)
Posted : April 28, 2014 11:20 am
You do know, don't you, that after you click "OK-Submit" you have a certain amount of time where you can edit the message. Look at your post a second time after you have posted it, and at the bottom, there is an "edit" link. That disappears after a certain amount of time.
Sorry if I am telling you something you already know.
Edit; I just came back in to my post. Above my typing window it says that I have 59 minutes to edit the post if no reply is posted earlier. So those must be the parameters.
Posted : April 28, 2014 11:24 am
(@stephen-ward)
I understand about the edit function, but these are different. It's as if they stopped typing mid-thought and often mid-sentence and clicked the submit button. On the example link I posted in the OP I was able to see the remainder of his post about 30 minutes later.
Firefox on Win7-64 for what it's worth.
Posted : April 28, 2014 11:29 am
