Help & Feedback
3
Posts
2
Users
0
Reactions
3
Views
I haven't been able to figure out how to post preformatted text like on the old forum, things like StarNet list files and other text with multiple spaces to make everything line up.
[pre]TEXT[/pre] worked on the old forum but not here 🙁
Posted : July 22, 2015 7:41 am
Test
JB,NMwolfvally,DT04-08-2015,TM14:06:16
MO,AD0,UN2,SF1.0,EC1,EO0.0,AU0
HA,N ,E ,TH,TE,RT,SC
CS,CO4,ZGUS State Plane 1983 (2011),ZNTennessee 4100,DNNAD 1983 (2011)
VA,PV2,N ,E ,LZ,SO,SA,GN
CS,CO2,ZG,ZN,DN
CG,AO1,GO1
DP,PN100
--Deleted 3:33:25 PM 4/8/2015
OC,OP100,N 5083.410,E 4749.233,EL100.000,--Tn
BK,OP100,BP101,BS42.27033,BC0.00000
DP,PN101
LS,HI5.5595,HR4.9700
DP,PN101
DP,PN101
DP,PN101
DP,PN101
DP,PN101
DP,PN101
DP,PN101
--Residuals: PN:101 dHz:0.00007
--Residuals: PN:101 dHz:0.00011
--Residuals: PN:101 dHz:0.00003
--Residuals: PN:101 dHz:-0.00003
--Residuals: PN:101 dHz:-0.00010
--Residuals: PN:101 dHz:-0.00008
BK,OP100,BP101,BS42.27040,BC0.00000
DP,PN101
DP,PN102
I think the CODE button on the toolbar will do what you want. It's the one to the left of the sarcasm button.
Posted : July 22, 2015 8:00 am
GROSS AREA INCLUDING HIGH WAY AND SIDE STREET:
Points entered clockwise.
Calculating...
J N22å¡57'04"E dist= 368.150 N= 10665.125 E= 14660.991 C'
C' S67å¡02'56"E dist= 66.000 N= 10639.389 E= 14721.766 C
C S23å¡31'00"E dist= 510.843 N= 10170.974 E= 14925.600 F
F S34å¡03'03"W dist= 100.000 N= 10088.120 E= 14869.607 F'
F' N55å¡56'57"W dist= 425.053 N= 10326.119 E= 14517.433 J
Results:
Square Feet : 113185.5 Acres : 2.598
NET AREA TO C/L OF VACATED R/W:
Calculating...
A N22å¡57'04"E dist= 233.674 N= 10597.474 E= 14704.017 B
B N22å¡57'04"E dist= 45.518 N= 10639.389 E= 14721.766 C
F N55å¡56'57"W dist= 61.532 N= 10205.427 E= 14874.618 G
G N55å¡56'57"W dist= 315.882 N= 10382.298 E= 14612.897 A
Results:
Square Feet : 51699.9 Acres : 1.187
AREA VACATED R/W SOUTHWESTERLY OF C/L:
Calculating...
G N23å¡31'00"W dist= 427.558 N= 10597.474 E= 14704.017 B
Results:
Square Feet : 15483.6 Acres : 0.355
AREA VACATED R/W NORTHEASTERLY OF C/L:
Calculating...
C N22å¡57'04"E dist= 45.518 N= 10681.304 E= 14739.516 D
D S23å¡31'00"E dist= 594.129 N= 10136.520 E= 14976.582 E
E N55å¡56'57"W dist= 61.532 N= 10170.974 E= 14925.600 F
F N23å¡31'00"W dist= 510.843 N= 10639.389 E= 14721.766 C
Results:
Square Feet : 18232.0 Acres : 0.419
Posted : July 22, 2015 8:10 am
