Trimble Geomatics O...
Trimble Geomatics Office error message
2 Users
(@timyoung)
I've been continuing to use TGO with the help of fixdatweek and rinexdates utilities, but have had an error today that I haven't met before. The converted rinex files (my data, plus those from the five nearest OS net stations - this is the UK) all appear to import into TGO fine, except that OS net stations show up as Receiver type of Geo Explorer 3.?ÿ
When I select survey - process GPS baselines, the first line appears to process (i.e. comes up with values for ratio, refvar, rms), but the process always fails on the second. The error is given as "PROGRAMMER/USER error: -19, C errno = 0: No error". I tried varying which lines are selected and it doesn't fail on any particular line, just the second.
Does anyone have any ideas where I might start to troubleshoot this? I assume it is an unexpected entry in the rinex?
Posted : 22/10/2018 8:42 am
(@christ-lambrecht)
Can you compare this 2nd line with older files of the same stations?
replace these lines if possible with the old data.?
Chr.
Posted : 22/10/2018 9:20 am
(@timyoung)
Good idea - I will try this. I do have some old data from the same stations somewhere...
Posted : 23/10/2018 7:13 am
(@christ-lambrecht)
Maybe these stations were updated and something went wrong with the new data.?ÿ
Here in Belgium the FlePOS system is updating receivers and software and we did have some bad RTK solutions due to these changes. Wrong parameters that resulted in errors of 5 to 10 cm in easting and in some cases in elevations. We were Warner by the automatic text-alert system.
good luck & keep us posted.
Posted : 23/10/2018 11:09 am
