tps files to rinex
2 Users
(@jmorgan)
Eminent Member Registered
Does anyone convert topcon tps files to rinex for use with TBC??ÿ My magnet tools subscription has expired and the office doesn't want to renew it so tbc is my only option at this moment.
Posted : 28/06/2022 10:14 am
(@frozennorth)
Honorable Member Registered
Yep, used to do it all the time.?ÿ Use a widget called tps2rinex.?ÿ Try a search for it here, might even be posted somewhere.?ÿ It's a weird little widget.?ÿ It has no interface and does not visibly launch.?ÿ You simply drag the tps file onto the tps2rinex.exe and it converts it.
Posted : 28/06/2022 10:17 am
(@frozennorth)
Should be able to grab it here, probably need to use/create a profile.
https://www.topconpositioning.com/support/products/tps2rin-converter
Posted : 28/06/2022 10:19 am
(@jmorgan)
@frozennorth I have it, and found it just haven't used it in a long time.?ÿ My company still works like we are in 1980, traverses are still done by hand with field notes, our gnss system is pretty much only used as rtk and only to set aerial targets.?ÿ I have been trying for years to drag us forward with little success.?ÿ?ÿ
Posted : 28/06/2022 10:57 am
Share:
