Raw Data Files edit...
Raw Data Files editing
2 Users
(@mwangy)
I seem to be in a bit of a pickle.
My setup is a ProMark 500 as a base and a ProMark 800 as a rover. MobileMapper 10 as a data collector and FAST Survey running.
I have just finished a static survey that I was doing in order to transfer control. The Raw data file at the base is fine as it is consistent. The problem is at the rover. It seems that as I logged data at the new sites and tagged a new site, I hit no on the window that popped up asking whether to continue logging the raw file.
After downloading the raw files they seem fine and the size I expect them to be. Even after importing them into GNSS solutions I can see the tagged sites and the rest of the approx. 20 min observations. The software however only sees the tiny tagged site duration. I am nearly pulling out my hair. my fix comes to 0.14 m which isn't acceptable.
Is there a way of editing the raw data file to make the software see the longer observation?
Posted : 09/05/2014 11:56 am
What does the RINEX file look like?
You may want to create and edit the RINEX file and import that into you post processor instead of the raw.
There should be commands in there to merge your raw files into one. It may be as simple as changing kinematic to static command.
Posted : 09/05/2014 5:02 pm
