Opus error
2 Users
(@larry-scott)
Noble Member Registered
Iƒ??ve been at this a long time. Sending data to opus is 2nd nature. I have Z12, I use it quite often, several times a month. I do have to fix the date. Never had an error for many dozens of submissions. Typical 70 min static, perfect conditions.
My question is: is this error data related, or is it an opus hiccup??ÿ
from the solution email:
STOP(rdrnx): error reading rinex file: /var/tmp/opus_local/RS72/21166/pool/wil11660.21o
data file:?ÿ
https://drive.google.com/file/d/18M5PtwkqqcRZvTYcI69V416XOsnL7B2l/view?usp=drivesdk
Posted : 15/06/2021 9:31 pm
(@larry-scott)
And of course with a Z12 I use OEM download and rinex conversion software. I also just got a Win10 update. So, Iƒ??m just curious: is this rinex 2.11 broken? Maybe Win10 update broke my workflow.?ÿ
Posted : 16/06/2021 3:07 am
Illustrious Member Registered
Delete the first three minutes of data till 22 42, P1 and P2 were not being fixed.
Posted : 16/06/2021 4:48 am
(@larry-scott)
@paul-in-pa?ÿ
thank you!!?ÿ
What a nightmare data set. I deleted 10 minutes, edited the header, opus hated it: ƒ??too short less than 7.5 minutesƒ??.?ÿ
so I deleted about 20 minutes, got another canƒ??t read rinex err. Screwed around a bit more, starting over.. blah blah .. but I won the battle. Now to re observe and see if I have systemic issue.?ÿ
I will not abandon my precious two Z-XII !!?ÿ
Posted : 16/06/2021 5:37 am
(@larry-scott)
@paul-in-pa?ÿ
and zeros on P for a few minutes is typical. But never had this amount of difficulty before.?ÿ
Posted : 16/06/2021 5:41 am
@larry-scott?ÿ
OPUS does not need the C or P values, but lack of them indicates that the L1 and L2 were not quite up to snuff. i.e. OPUS-RS would not except those files, since it depends on the early observations to determine if the file is good. Zs are slow to get up to speed and when that was all I used I helped them along by steering them to get the available satellites quicker without looking through the whole galaxy. If the file ends up short of 2 hours, that's OK because by the time you've done all this fiddling OPUS-RS is ready to get to work.
Posted : 16/06/2021 11:37 am
(@larry-scott)
Iƒ??ve not encountered that error before. So itƒ??s usually 1-2 minutes and a screen full of LK and LZ. (I didnƒ??t monitor the screen, theyƒ??ve been fire and forget.) mostly I do 60-90 minutes, more is just the same.?ÿ
software advances in the past several yrs actually make Z work better than when they were new and a hot ticket. Now theyƒ??re just too heavy.
For my application, theyƒ??re still great.?ÿ
thanks, I shouldƒ??ve been more aggressive with cutting it down. One forgets the basics when itƒ??s been so easy for so long.?ÿ
Posted : 16/06/2021 11:46 am
Share:
