NGS data sheets
1 Users
(@larry-scott)
I’m having trouble retrieving an NGS data sheet.
I had used an NGS mark 3 yrs ago and it’s pub lat long elev. I have its coords keyed into MicroSurvey (Starnet). Fit perfectly. I had found the mark by radial search, using handheld gps, all is well.
What I can’t find is that data sheet, and pid.
The disc is stamped ‘BOUNDARY MON NO 97 1939’.It’s an RM or AZ mk disc.
Searching on BOUNDARY MON 97, that data sheet shows there is an az mk indicated: CJ8178. I’m pretty sure this is the mark I used.
However there is no mark symbol on the NGS graphic search at this location, and search for pid CJ8178 is ‘not found’ in the search box.
So, is there a separate search for archive data sheets?
I really need the sheet for citation as I used it in a survey and for completeness. I thought I had properly saved the data sheet, but I’m back peddling.
39-43-21.862970 77-37-13.64713 ortho 190.092
All I can figure is it’s destroyed  mark and removed from the search. So where can I find CJ8178 that is on the primary data sheet for BOUNDARY MON 97?
Posted : November 26, 2024 8:24 pm
(@larry-scott)
Posted : November 26, 2024 9:25 pm
