Another example of why I refuse to work for big box contracting companies, and why the profession needs to shore up its value by refusing to work for people that dont understand what the job really entails.....
About the job
Description
As an Assistant Surveyor, you will assist with the performance of fieldwork on construction sites by conducting vertical and horizontal control surveys, performing data processing and analysis, and recording survey data for construction and civil engineering projects. You may also travel to job sites at different stages of construction and work in all types of terrain and weather conditions.
Additional Skills & Qualifications
Strong communication skills
Ability to contribute and work well on a team
Associate degree or 2 years experience with a licensed surveyor
Some construction experience is helpful
Experience Level
Entry Level - Mid Level
Umm... I read that 3 times. I don't see a problem - what'd I miss?
Fair.
The mid level is kinda where I get chafed. Associate degree in what? 2 years of pounding nails and cutting brush or have you been processing control and doing network adjustment for analysis and collecting the data you're processing.
I guess I don't know what to expect anymore.?ÿ Sorry for the delivery.
Delete will follow..
I have no issues with it.
Associate degree in anything. Shows an awareness for self improvement. Alternatively, if you have two years of experience, you will considered.
Two years of pounding nails and cutting brush is not surveying. That's laboring.
The ad says "will assist", not ability do on your own. Doing that on your own would be "senior level".
There are plenty of problems with our industry regarding entry level pay, experience expectations, career advancement opportunities, but this add isn't one of them.
WHY???
I'm a huge advocate for education, particularly a bachelor's degree in surveying.?ÿ But not every job is surveying requires a degree. Jobs that do require a bachelor's degree should have an obvious career track to professional licensing.
This is an entry level position.
