I have a GPS project with observations on Saturday October 20, 2012, day 294, that may have to redone differently because the data for the nearest CORS is missing from NGS. I find out that this county CORS site is now operated by Leica's SmartNet. I am not a subscriber as I rely on OPUS-S and OPUS-RS for static control surveys.
If there is a SmartNet user out there that has access to RINEX data other than through NGS I would appreciate a check on data availability. If you are inclined I need 4 hours of 10 second data from 14:00 to 18:00 UTC. email to my profile would work.
Usually this is just a communications link with NGS that soon gets resolved and stored data shows up late. If not I need to redo with longer observation times as elevations are required and I have a mix of L1/L2 and L1 receivers. Actually my L1 observations were of better quality.
Thanks in advance.
Paul,
Have you checked out the website for the local Leica dealer? I know that the data is available for non-subscribers in the form of a zip file. It is broken down into hour long segments, if I remember correctly.
I hope this helps.
Jimmy
Edit: The data is available for the Leica stations in our area (West TN)
