OPUS Antenna Questi...
OPUS Antenna Question
2 Users
(@wrquinn)
I am running a static point on a recently acquired old 5700/r7 with out bluetooth. the antenna is one of the older zephyr geodetic L1/L2. I usually am using the R6 and 5800. when submitting them to opus, the model is easily found in the dropdown menu for the Antenna type. Which Antenna type should i select on the OPUS screen when using the old R& and Zephyr geodetic?
Thanks in advance,
Posted : May 31, 2013 8:08 am
(@brian-allen)
I think have a similar one, PN 39105-00 DC 4212. Look at the PN on the antenna, for mine I would try the OPUS listed TRM 39105.00 "Zephr 4 point feed antenna, no ground plane"
Posted : May 31, 2013 8:21 am
(@wrquinn)
When I used the convert to rinex program. it has the antenna settings for the file as trm41249.00. lets see if it works! I am trying to set up a base station at my house using the NTRIP utilities. This is the first shots that i am getting after setting the antenna yesterday. If anyone knows of a NTRIP guru in central Texas let me know.
Thanks,
Posted : May 31, 2013 8:44 am
