Attached is a level reduction spreadsheet.?ÿ Simple stuff I know, but, it does automate the adjustment.?ÿ Thought someone else might need it sometime to save a minute or two.?ÿ I just save a copy of the sheet in the directory for the job with the note's date added to the description.?ÿ Add and remove cells as blocks to keep the integrity of the sheet as shown here:
The rod or sideshots will not show until data is in the appropriate "F" cell.?ÿ If you need to add more rod shots, you will have to do some cell modification.?ÿ One way levels make sure that the two "should be" elevations are correct and of course always watch the total error sum under column "C"
It is easier to not fill out an item than to make room for more, so, a revision is attached.?ÿ If there is no measurement leave the cell blank so it isn't counted as a response
