I was given a Leica HDS6200 and it had power in the batteries for a short time.?ÿ But now the batteries are drained and I dont have the 400 dollar power adapter cable.?ÿ Does anyone know how I can charge the batteries manually with low voltage.?ÿ This method hasnt worked for me on this unit, I have tried removing the battery pack and using pins into the serial port (2 positives and one negative).?ÿ The batteries charged up this way but the unit doesn't turn on, I suspect there is a 2 or 3rd internal battery that needs to be charged.?ÿ Perhaps someone knows which of the 3 pins at the base of the unit will charge the scanner??ÿ (There is no voltage coming to the pins from the battery pack when connected even though I know the scanner has voltage).....Or perhaps someone can make me or sell me the appropriate amp/voltage for this scanner....obviously must be less then 400 bucks.?ÿ Mostly, I want to just mess around with the scanner, learn it and perhaps use it after I learn the software.?ÿ?ÿ
Thank you
If they don't have one they may make one for you.
Hi,
Just came across with your post. Were you able to solve your problem with HDS6200? If not or still having problem with it let me know, I may help.
Be well,
