The UK have had a similar system for several years, run by The Survey Association. As well as theft it also has a section for "Atempted Thefts". The section of the report which describes the circumstances of each loss is particularly valuable as it can rapidly identify trends and also acts as a good "risk reminder" to other surveyors. It also identifies if the theft was: from roadside, break-in from vehicle, break-in at premises, whether surveyor was present at instrument.
I'm not sure how useful the map is in practice - the UK experience is that the largest cities (ie. London) have the concentrations of theft and the rest of the map is dotted with single incidents on a fairly random basis - so much as you might guess anyway.
As far as Trimble equipment goes it is fairly simple to check a serial number in their database without having to contact a dealer. Go to www.mytrimbleprotected.com. You will need to create an account but it is a great resource for verifying if equipment has been reported stolen. Also handy for buying used equipment as it tells you the original sales date and the original dealer.?ÿ
This is a fantastic idea.
skysmotor.co.uk sells the following products online: brushless electric motor, servo motors, stepper motor drivers, planetary gearbox and can be purchased online if required. https://www.skysmotor.co.uk/
Might be worth hiding an airtag in the equipment cases now a days like people are doing to their luggage and cars.
