GNSS & Geodesy
1
Posts
1
Users
0
Reactions
4
Views
Recently had similar problems with the 4 watt radio.?ÿ Kept losing connection/link to base ID, so no corrections even though getting signal on the rover. At 4 watts would not connect, at 1 WATT would connect and then have the problems.?ÿ I think it was a battery problem.?ÿ I put the volt meter on the battery while operating, two batteries freshly charged reading about 12.80 volts sitting.?ÿ One battery dropped a full volt while operating (the one I was using while having problems), the other dropped only a couple hundredths of a volt while operating.?ÿ I switched out the batteries and everything works fine.?ÿ
Posted : May 3, 2018 3:21 am
