I need to process large quantities of base line simultaneously. After TBC executes the baseline processing, there are a large number of baselines which are still in float. For processing these base lines, i need to clean the data for each line physically to bring them from float to fixed. To do this, I look at the Residuals graph generated by the baseline report and use the session editor to clear the areas where the data look abrupt or too far from the mean ( a likely cause for the baseline to be in float). After a couple of hits and trials I am manage to bring the baseline into float.
My query is: Is there a way to filter out the bad patches of data from the session editor automatically?
While probably not the answer you are looking for, I would see whether there was a correlation between the bad data periods and low elevation angle. If there was, I'd incrementally raise the elevation mask. Downside is some reduction in geometric strength for the solution of tropo parameters.
