Notary question
8 Users
(@thoth99)
Active Member Registered
I've always worked at companies that have an employee who is a notary public. If you start a survey business on your own, can you become a notary yourself? Probably a dumb question but I don't know the rules yet.
Posted : 21/10/2023 5:05 am
Check online with the Secretary of State Office for your geographic area.
Here are the requirements for Kansas for an example.
https://sos.ks.gov/business/notary.html#:~:text=To%20be%20eligible%20to%20be,is%20regularly%20employed%20in%20Kansas.
Posted : 21/10/2023 5:27 am
Illustrious Member Registered
Yes, you can.
Posted : 21/10/2023 7:06 am
(@mathteacher)
Noble Member Registered
A notary cannot legally notarize a his own signature nor a document in which his name appears.
Posted : 21/10/2023 9:50 am
Your mileage may vary.
I've seen plenty of notary stamps, by the surveyor that stamped the survey, for his client that signed the survey to adjust a boundary or create a subdivision.
Like Mr. Cow suggested; check with your state...
Dougie
Posted : 22/10/2023 2:12 am
(@ashton)
Honorable Member Registered
I'm a notary in Vermont. There's a good chance you or someone in your firm can become a notary in your state. But laws vary from state to state about whether an employee-notary can notarize a document that pertains to the company they work for. And as others have said, notarizing a document that the notary signed as a principal (e.g. corporate officer, surveyor, or survey technician) would not be allowed. Not so clear if the notary's name appears but the notary didn't sign it.
One exception is a state where a notary can certify a paper copy of a document that was notarized electronically. If the notary performed an act electronically and signed the document electronically as a notary, the same notary could print it out and certify the printout as a true copy.
Posted : 22/10/2023 3:32 am
I know lawyers who are notaries, PE's that are notaries, I don't know any surveyors that are notaries, but there is no rule against it. You will have to pay attention to your state's rules, but otherwise go for it.
Posted : 22/10/2023 3:42 am
(@mathteacher)
Can you notarize your own documents? - PandaDoc Notary
Posted : 22/10/2023 8:15 pm
(@ralphieboy)
Trusted Member Registered
I was an NC notary for a bit years ago, but let it lapse. As I remember, you were not supposed to notarize anything that you had an interest in? I found this on a quick peruse...
https://www.notarypublicstamps.com/articles/why-notaries-cannot-notarize-their-own-documents/
Posted : 22/10/2023 9:09 pm
(@hi-staker)
Reputable Member Registered
I am a notary and a PLS. I refuse to notarize any document that I am signing as a PLS, not only because it is illegal in Montana, but also because it is a blatant conflict of interest.
Posted : 24/10/2023 7:50 am
@hi-staker thank you for posting this.
I've seen several recorded surveys for boundary line adjustments and small subdivisions; where the surveyor stamping and signing the document is also the notary stamping and signing the document.
Guess they figure it's only going to be a problem if somebody makes it a problem. risky business in my book...
Posted : 24/10/2023 8:51 am
3
Posted : 24/10/2023 10:55 am
2
Posted : 24/10/2023 11:06 am
1
Posted : 24/10/2023 11:11 am
Share:
