Questions after a s...
Questions after a survey disagreement
22 Users
(@cee-gee)
Honorable Member Registered
Here's the whole plan. As a Maine licensee I note that it does not state specifically whether it's oriented to True or Mag. or anything else. Mag was in common use in this area in 1984, and likely the basis of most of the survey plans done about then, and I believe there's a Maine Law Court decision somewhere that ruled that Mag. is to be presumed as the basis of survey bearings unless something else is explicitly indicated. Our Board's website says the surveyor who did the plan let his license lapse in 1995 and thus is evidently retired, otherwise I would have urged Jason to get him into the picture.
Demo plan
Posted : 13/01/2023 4:44 pm
(@mathew-stuesser)
Active Member Registered
@norman-oklahoma I wish there was a like button so I could like your comment lol.
Posted : 14/01/2023 5:48 am
GaryG
(@gary_g)
Honorable Member Customer
WOW !?ÿ
Posted : 14/01/2023 6:42 am
(@rover83)
Noble Member Registered
Good on @cee-gee for posting the full subdivision/plan.
That being said, we are all still in the dark about what, exactly, the OP is "challenging".
Posted : 14/01/2023 7:03 am
(@on_point)
Estimable Member Registered
The more I look at the plat the more I agree with an above comment that itƒ??s likely there is an issue with the original survey or monuments. I think if I were surveying one of those lots and run across the discrepancy ?ÿafter all this time, I would be inclined to hold the original survey corners (if all the bearings and distances agree with the other lots) since itƒ??s been the accepted boundary for all these years unless otherwise decided in court and just make note of the discrepancy and evidence suggesting a discrepancy on the plat and description. When it all comes down to it courts generally err on the side of whatƒ??s been established as boundary in the past.(not sure if I explained that very well)
Posted : 14/01/2023 9:55 am
(@rover83)
@on_point
I don't know how anyone can say anything about the state of the lot or the original subdivision. That plat is the only hard piece of evidence that we have seen so far. Absent any other evidence, there's nothing to analyze.
Posted : 14/01/2023 12:03 pm
(@oldpacer)
I know the mapping quality is poor, but I had to check. I think when the neighbors got together; they found a corners on the river and corners on East Spruce Drive. The surveyor, thinking this was going to be easy, ran a bearing between two of the corners that was close to the number on the plat. The plat bearings are about 15?øout from True North. The aerial indicates alignment pictorially like the plat line and not like the orange lines. I think the surveyor got it in his mind what the neighbors showed him and never tied enough corners to determine where in the world is Carmen Santiago.
Posted : 14/01/2023 12:36 pm
(@jon-payne)
That is certainly a possibility, but we still haven't actually seen the more recent survey work and have no idea where the orange lines shown on the image the OP posted came from.
It is also possible that the lot owner has it set in his mind exactly what he wants to be his land and therefore sees the line as being different than the drawing without knowing.?ÿ I know I have had to patiently explain why something someone "knew" did not jive with reality plenty of times.
Too many unknown pieces of information to even provide a suggestion other than to get in touch with the surveyor recently hired and seek a more detailed explanation (and do so trying block off preconceived 'I'm right your wrong' ideas).
OR
Hire another surveyor for a second opinion.
Posted : 14/01/2023 2:11 pm
(@on_point)
You are correct, itƒ??s hard to say much with so little evidence, it would be nice if the OP could offer more evidence. Perhaps post a comparison of the original plat and description and the new plat and description. I was only offering an opinion based on the hypothetical scenario the OP gave which is only one side of the story. We really canƒ??t tell if the original and new survey are different until we compare them side by side or until we see it staked on the ground.?ÿ
Posted : 14/01/2023 4:36 pm
not-my-real-name
(@not-my-real-name)
Noble Member Customer
Asking who drew the orange lines would be a good question.
Posted : 14/01/2023 5:02 pm
(@oldpacer)
Opps, lost the map.
Anson
Posted : 14/01/2023 7:50 pm
In a subdivsion, every tract is related to every other tract.?ÿ You cannot modify one without modifying all.?ÿ You don't get to pick and choose.
Posted : 15/01/2023 8:47 am
(@mattsib79)
Reputable Member Registered
I have found things similar to this on rare occasion from surveys done in the 50's around certain lakes.?ÿ They would run a traverse line around the lake and close that loop and then run a spur line into the middle of the subdivision.?ÿ Distances all match along the road.?ÿ Distances match along the lake but the angles do not match.?ÿ Again I do want to say that it is rare.?ÿ?ÿ
Posted : 08/02/2023 12:49 pm
(@eddycreek)
@mattsib79?ÿ
Sounds like you've worked around Barkley Lake where that's not rare at all.?ÿ Except the boundary is just copied from the Corps of Engineers survey and the rest of it is done with a compass and wheel through the hills and hollers not tied to the boundary in any particular way.
Posted : 08/02/2023 12:53 pm
(@mattsib79)
I have seen things like that in a couple of subdivisions along Rough River Lake.?ÿ Although I would assume it has happened along many of the lakes built in that same era.?ÿ?ÿ
Posted : 08/02/2023 12:56 pm
Page 2 / 3
Share:
