Dear Surveyors,
I am a terminologist working on an information management project that involves defining some complex concepts, and I would appreciate your expert input. This is my understand so far, with some key concepts in italics:
An easting/northing is the plane equivalent of a latitude/longitude: each is a coordinate, which amounts to a value in terms of a distance or angle respectively, in the set of coordinates that their coordinate system specifies. Just as a latitude/longitude is not considered a line, an easting/northing is not a line either. However, just as we can say that a parallel/meridian is a line with a particular latitude/longitude, we could say that a north-south line has the same easting value.
Does anything seem grossly incorrect in the above paragraph?
I appreciate your help.
a distance or angle
a distance from an axis of the coordinate system.
I don't see that an angle has any need to be mentioned in that sentence.
The whole paragraph seems clumsy. In that i see no need to argue about lines at all.
Meridians are lines with the same Longitude, not the same Latitude/Longitude. That is a point not a line.
Northings and eastings are values that communicate distance from their respective reference axes.
Latitudes and longitudes are values as well, but they communicate angles from their respective reference planes.
Just as one latitude value and one longitude value taken together (pair of coordinates) communicate a single point on a sphere or an ellipsoid, one easting value and one northing value taken together (pair of coordinates) communicate a single point on a plane.
In that sense they are equivalent in that a coordinate pair defines a single point.
Beyond that, I would think that discussion of lines would need to be its own section...planar lines are pretty simple but when discussing spheres or ellipsoids there's a need to discuss geodesics, rhumb/loxodromes, great circles, etc...
What you have written is OK, notwithstanding some esoteric trivia. I'd amend the line above just slightly, for clarity, as follows:
just as we can say that a parallel or a meridian is a line with a particular latitude or longitude
There are all sorts of coordinate systems. My Northing and Eastings may or may not result in true (whatever that means to you) North - South directions on the globe.
I see what is being attempted, but if someone understands projections (which if you have eastings and northings, then you have a projection of some sort, I would guess) then they should already know what the paragraph states.
Dear Surveyors,
HI
those terms already defined in the NSPS Definitions of Surveying. Why add to the confusion?
Coordinates expressed as northings (N) and eastings (E) define the location of a point in a 2D-rectilinear system derived from ellipsoidal latitudes and longitudes via projection parameters particular to its politically-defined location. Points expressed as N and E values are not linked to the geocenter.
The relationship between any two points in a rectilinear system can be derived through plane trigonometry.
In the US the main implementation of rectangular coordinate systems is the State Plane Coordinate System. Prior to the adoption of the North American Datum of 1983, the National Geodetic Datum of 1927 expressed SPCS coordinates as X and Y values.
Please note that a 3-dimensional coordinate systems have been developed to express latitude, longitude and ellipsoid height values (for a point or a vector) in terms X,Y,Z (earth-centered earth-fixed) with their values being with respect to geocenter. Local Geodetic Horizon coordinates expressed in North, East and Up can be derived from known latitudes and longitudes plus XYZ coordinates using rotation matrices.
Over-explaining as usual… To damned hot to get out of the house.
LAH and LGH copied from NGS TM 47 describing design and use of the NGS program ADJUST by D Milbert and W Kass (1987).
https://geodesy.noaa.gov/library/pdfs/NOAA_TM_NOS_NGS_0047.pdf
As usual, a picture is worth a thousand words…
I think folks are getting hung up on the projection piece.
I could be wrong, but based on the OP, it doesn't seem like there is a need to explain or discuss projections, distortion, ECEF, etc., just the bare essentials of what northings and eastings are, and how they are similar to latitude/longitude, as an aid for users reading about the term.
We NEVER get hung up on this sort of thing!
Northings and Eastings; Latitudes and Longitudes, by themselves, are lines. When used together, they are points.
A simple grid is a good example. X and Y are the lines forming the graph. X,Y are the points of intersections.
Thank you all for your help so far. I have incorporated your input into the project.
Also, as far as I know, nobody uses negative values.
Using a set of two northings and eastings, a distance and a direction. Using a set of three, an angle.
